Need Help on CCX Error
I have a sector model of a disk to be analyzed. I get the following error when I run the case. Can someone help me with this? Thanks
  • edited March 7
    I haven't done this for a living for over 15 years so I might be a little rusty.
    I used the Mecway cyclic symmetry feature, put your DLOAD in the custom step contents and changed how you hold the hub. Strictly speaking your load is symmetric so you could simply run with symmetry at the cut boundaries, but I tested the model with an out-of-plane non-symmetric load (suppressed pressure) and results seemed okay as well.
  • Thank you. Just realized I had my cards reversed
