Tested a model similar to the one you show. Different formats attempted:
Dxf: No good. Automesh 2D just blanket fills everything within the outer perimeter.
STL: Success. All regions meshed.
STEP: Success. All regions meshed.
Edit: Although its more work, you can get dxf to work if you first create a parting line down the middle and erase, say, the lower half -- essentially removing/opening up the interior spaces (it now resembles a hair comb). Once Automesh does its thing, use the Mirror-Copy command about the part.line to restore the part.
- Dxf: No good. Automesh 2D just blanket fills everything within the outer perimeter.
- STL: Success. All regions meshed.
- STEP: Success. All regions meshed.
